Discuss Leak in Airing Cupboard Tank in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
The pipework around the hot water tank in the airing cupboard has developed several leaks after a chemical flush.
It's an open vented system.
Any ideas on controlling or fixing the leak?
Should I turn off the red valve (pic 1) that has a leak next to it and rundown the hot water?
Pic 2 a vertical pipe has also developed a leak at the top. Black water is dripping out.
Unfortunately there is still black water in the system after the chemical flush.
Any help appreciated. Thanks
Have you tried closing the air tap a bit more eg the brass by the towels
Reply to Leak in Airing Cupboard Tank in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
