Discuss Kitchen tap advice please in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi, basic question. I have a leaking kitchen tap. I'm a bit confused on the part I need to get.
On Screwfix I can see "Flomasta 1/2 inch BSP quarter turn ceramic tap glands" - are these the right parts?
But I can also see 8x8mm 20-tooth spines, 9x9mm 20-Tooth Spines and others - which of these would I need to get?
Many thanks for your help.
go to your local plumbers merchants they have a gauge to check the splines and if you req. hot or cold side.
Reply to Kitchen tap advice please in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
