Discuss Kitchen draw hitting gas stopcock in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, I have just had a Magnet kitchen installed and a new hob fitted on the 18th of May. It came to my attention shortly after, that the back of middle draw in the unit under the hob is just hitting the gas stopcock, I would say that the draw is not closing fully by about 0.5 to 1 mm. After several text messages, and his agreeance to come out, but failing to do so, I again asked if he would come out next week, his reply was "yes mate but I will have to charge to re-do this". My question is, is this unsafe? the draw is soft close and the back is made of thin flexible steel. I have his gas safe registration number on his certificate.
Depends do you mind looking at a eg you could drill a hole the same size so the draw fits over the valve
Get him back, and he shouldn’t be charging for the work as he’s not made sure you’re satisfied, nor is it satisfactory workmanship.
The point I was making is this
The GSR probably put the gas in BEFORE the kitchen was fitted, in the absence of a complete specification installed his work properly. So why should he carry the can ? The electrics look a bit near the knuckle as well in my opinion
is that a standard width utility space ...Rob Foster aka centralheatking
Perhaps yes, but also perhaps this could have been talked about (not dismissing it) at design and installation stage?
Make Magnet pay, its their fault
in my opinion, they designed it I suppose and did not specify the clearance at the back, 99 x out of 100 they will get some fall guy to pay for the short falls in their specification. If that was a Health Service install it would NEVER be signed off
I know done plenty of medical work and the same standards should apply...Rob Foster aka centralheatking
Something like an rf switch maybe ?
The unit is plugged in to a socket really tight so how can it be serviced etc...very poor ..but this is always the interface with
kitchen designers, plumbers, GSr, tilers, plasterer it goes on
which is why if you have enough lolly get a proper outfit in whom will co ordinate everthing and MOST important
sort out the Snagging which is absent here
Draw pulls out probably
In the real world this is the sort of thing that happens ( don’t forget op said 0.5 - 1mm).
I’m glad kitchen fitter didn’t just rotate fitting as he probably didn’t have nouse/equipment to check it wasn’t leaking.
5 seconds with hammer at time of install and I guarantee no-one would have been any the wiser and all would be good with the world.
The gas tap was there from the old hob in the previous kitchen installation.
I agree that turning the tap just a few degrees would fix it, and he was told about this.
I guess I was half hoping that you guys would say that this tap being hit many times over time could be unsafe; this would give me more clout when I approach Magnet for a resolution.
I paid Magnet for their gold installation package, which included the installation of gas and electrical units, so they are inevitably responsible to get this sorted.
Once again thanks for your time and help
In terms of classification:
  • at the present moment in time: not to current standards
  • over time: at risk (mechanical damage)
  • Eventually a gas escape would then become immediately dangerous
All in my opinion of course.
It’s 0.5mm, for all we know the gas safe could’ve got it all spot on - then the kitchen fitter scribed the unit in to allow for out of square and this created a problem with the valve.
These things are not always as they seem, as most of us know....
Just a quick update, the gas tap was left in place from the original kitchen fit during the new fit, when completed the gas safe fitter fitted the hob and connected it to the tap, his first attempt stopped the top draw from closing, so he had to do more work to rectify this. Anyway I will speak to Magnet along with the text messages, and photographic evidence, and see what they say. Thanks again for your time and input.
Don’t call them. Email so that you have a paper trail.
Reply to Kitchen draw hitting gas stopcock in the Plumbing Jobs | The Job-board area at PlumbersForums.net
