Discuss Keston boilers in the Plumbing Jobs | The Job-board area at PlumbersForums.net
SafeGasInstall
Subscribed
Merry X mas to you all !!!
Just wondered if can any one explain what is so special with this type of boilers ,that they so expansive !have never come a cross one !
thx you !!!
Basically they are so expensive as it takes a lot of man power and time to make a boiler of such poor quality look so good !!
If you have never come across one, you have been blessed, try to hold on to that record
They are good for a few years and then turn into Lemons
If anyone has one, usually around the s/w London area, you must get them checked every year, which with their life span is only four checks at most
imho
got some right pics of one at a mansion i went to, when i find me bluetooth i will download them.
ive been to 2 kestons this week. they are in the same league as ravenheat and sime if not even worse.
Nice keston in a nice large house located in the boiler room,
spot any problems?.
That dark patch on the wall is an inch deep btw.
Reply to Keston boilers in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have an ideal vogue max S18 boiler and I’m considering fitting auto balancing TRVs, my question relates to the boilers pump. I see a boiler...
PSxxxxxx
Can anyone recommend a decent multi meter, preferably under a 100 pounds. It's for checking boiler components so I don't need a top spec one...
Recently had a Viessmann Vitodens combi boiler installed, quite often when the adjacent cold mixer tap is opened the boiler starts for a few...
