Discuss Joint leak - what is this brown stuff ? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
billy wedlock
Hi, what is this brown stuff
f from this joint ? Just water leaking via joint tape ?
Different people use different methods to seal joints.
it looks like hemp has been youed to do the joint in stead of ptfe tape and some inhibiters are dark in colour which may when leaking look like this
Looks like the leak may be coming from the vent or blank plug. Looks like it's tracking down the rad. Nasty looking joint that though.
Billy are you just wanting to know what it is or want to sort it ?
Take the tails out and use some loctite 55 if you want the latter.
As above, it looks like hemp and some type of paste
If it isn't leaking, run a junior hacksaw blade around the threads to tidy it up
If it's leaking, do what townfanjon says
There's defo water running down from further up though
EDIT use the hacksaw blade whilst out of the saw frame, lightly
Hemp and compound. Very untidy work too! Leak is from above you can see in the pictute. be the bleed plug or blank at the top.
Reply to Joint leak - what is this brown stuff ? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello I have a condensate pipe that appears to be leaking at the joint. How do I fix the leak? Would something like plumbers putty around the joint work or does it need to be some other compound? Can I simply pull the pipe and joint out and then put the compound round it Thanks
Expansion Tank leaking into ceiling - not the joints Scared might have deluge so have turned off supply and drained tank - can I leave for a few days pending replacement?
Hi all, I have a couple of leaks coming under shower tray downstairs. One is along the wall so think might be joint between wall and tray and the other seems to be near waste tray, there is a slight hairline crack in shower tray near waste . This happens when I leave the shower head near the...
Not exactly a plumbing problem but here goes. I have known for a couple of years there was a water leak somewhere between the water meter, on our property, and the property itself. The water company fitted a new (smart) meter about 4 weeks ago. Now they have contacted us saying we have a leak...
1K
Z
I'm trying to remove the zone valve ion vented tank and the tank started leaking around the joint. I was hoping to just run the tank with immersion till I can get an unvented. Any tips to stop leaks or do you think I need to buy temporary tank. Any help appreciated as I'm without hot water now.
zacwithleak
Z
