Discuss I've settled on an Intergas boiler. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have posted a few times, mainly regarding my indecision to go for either an Ideal or an Intergas open vent boiler.
Having taken note of comments here and having, today, visited [with my installer] a local Plumbase shop to see the area Representative/Contracts Manager displaying an Xclusive combi boiler I (we) have pretty much decided to go for a 30kw Xclusive Combi. The bigger (36kw) is a bit too tall to fit the space).
Initially, and by way of a sort of compromise, I will probably have it fitted as an OPEN VENT boiler which fulfills my desire for retaining an unpressurised system and in keeping the F & E in place - and will upgrade to a full combi heating system at a later stage - i.e. if the hot water cylinder starts to leak or something else forces my hand.
The feeds to the boiler are currently from above and I'm told there isn't a stand off frame currently available and in order to run the pipes behind the boiler the rep. suggested standing the boiler off the wall using two lengths of 2" x 2" and a board made from something like 18mm ply. Both the rep. and the guy in technical confirm there's no need for a heat resistant backboard.
I have a 22mm gas supply to the boiler. I'll fit a Magnaclean Pro 2 and will have the system flushed. I'll change the present manual bypass (in the cylinder cupboard) for an automatic one. I have already run a 3 plus earth cable from the cylinder to the boiler.
What, I wonder, have I missed?
Thanks to all who advised previously and led me towards the Intergas option.
Don't believe it will work as an open vent. Instructions say below 0.5bar, you will get a low pressure warning and the heating will function at a reduced capacity. 0.2bar and below and the heating won't function.
Also, why keep the cylinder when fitting a combi?
Ah - there you have me. I am only going by what the Southern Area Contracts Manager tells us when he demonstrated the boiler today.. And the fact that all their advertising blurb says you can run them as open vent. Obviously I can't speak from any position of authority myself. I will need to be satisfied that either he's right or you're right.
The idea of keeping the cylinder relates to the fact that originally I was determined to replace the old open vent Ideal boiler on a 'one for one' basis - keeping it simple by retaining the F and E and seperate Grundfos pump and the three way valve etc.
Then it seemed that I could keep my options open by just fitting the Xclusive combi and keeping the open vent system and being able to convert to full combi operation at a later stage if need be. That way I get my wish to keep an open vent system in the short term but can conform to everyone elses recommedation to have a combi - at some later date.
Many thanks for the quick and very pertinent reply!
You can have it as an open vent so long as you can maintain 0.5bar pressure. Not knowing the distance between the base of your header tank and the top of your boiler, I can't say whether the required pressure can met.
That will give you approx 0.36 bar of pressure. If you can raise the tank a further 1.4 metres that should give you enough pressure for the boiler to function correctly.
That's completely up to you. Is there a reason your wanting to keep your system as an open vent? Is there a real risk of pipes bursting etc or is it just a fear you have?
The latter. It's a 23 year old 10mm microbore system with the ground floor fed from drops in the first floor void and the manifold is under 8 x 4 sheets of tongue and groove chip which is under tidy carpet etc, I dread the thought of a leak caused by me pressurising the system when I could have left it as it was. However - everyone tells me not to worry.
It is a risk that I tell all my customers when upgrading systems. However I have only had it twice where the increased pressure caused any issues. One was corroded copper and the other was burst radiators so your risk is minimum.
Maybe stop and listen to what pros are telling you -
All received.
The trouble is the pros have told me all sorts.
1. Fit the one with longest warranty
2. The warranty will be worthless coz they'll wriggle out of it.
3. Fit an Ideal.
4. Fit an Intergas.
5. Fit a Worcester or a Vaillant.
6. A replacement Heat Only open vent will be the easiest and cheapest option, so do that.
7. A sealed systyem is the way to go.
I admit the majority say sealed rather than open.
I don’t know why you’re dead set on Intergas where they’ve had issue with warranty parts ie obtaining them.
Start again:
What do you want to achieve for your money?
You have to understand we can only lead you so far. You have to make the final decision yourself. How many quotes have you actually had??
I had one local company quote a year or so ago - they offered a number of options but favoured Worcester at the time. They told me to consider an unvented cylinder and system boiler and spoke about other upgrades to the programmer etc.
No other quotes because, as mentioned elsewhere, I have a long standing mate who has fitted Glowworm, Baxi and Ideal - and who doesn't rate WB or Vaillant and has only recently become interested in Intergas.
I honestly am spending time looking at options - the existing Ideal Classic FanFare 250 is OK but I realise it could fail (expensively) and I think I ought to be ready (in case it does fail overnight :))
If it's considered that I'm taking the time of forum contributors unnecessarily then I need to be told - but till then I'm learning and hoping to do the right thing.
We are happy to help but it does seem that whatever we say to you, you keep coming back to Intergas. I know there are some guys on here that rate them but in my eyes they are a bit of a gimmick and a bit of an unknown quantity in terms of longevity. I’d be far more inclined to go with a Vaillant or a Glowworm as on the rare occasions I’ve had to use them the aftersales service has been second to none. Further down the line you will also not struggle to get parts. The amount of ball ache you have had just trying to sort that stand off and flueing issue would have been sorted in two minutes flat with one of the above named. Just my opinion but perhaps don’t use your mate. He has his opinion it doesn’t have to be yours
Again I say "all received" and further grateful thanks. He has fitted Glowworm (he put a combi in my neighbour opposite's place). He tends to reckon WB are a tad overrated and not that simple to work on. But, as has been said, every installer has his favourites for whatever reason - be that cashback or freebies or just that they find one manufacturer to be better at backup or more reliable???
I hear your thoughts re IG and would just say that I do feel so confused when so many contributors have such conflicting experiences with ALL of the usual names - but the feedback I seem to see about IG seems pretty universally positive. BUT, comments on the forums don't tell the whole story, as we all know.
All food for thought though - and I remain grateful.
Were it me I’d get three quotes from different companies. See what they suggest and ask them why. I bet none of them suggest IG. Worcester are overrated because their boilers are not the quality build they once were and their service dept is now dire
Just in case you have missed this, the CH output of the Xclusive 30 is (100%) factory adjusted to 19.4 kw output, probably no big deal except that you are heating large amounts of hot water at the same time.
https://www.freeboilermanuals.com/assets/pdf/intergas/xclusive.pdf
Seems a daft idea to fit a boiler which is really a combi then decide to use it as an Open Vent boiler (Another gripe of mine about Intergas but that's another thread).
Decide what you want exactly rather than trying to compromise. If you want a combi, do the full conversion now. If you want to keep your cylinder have a system boiler and make it a sealed system.
I convert all systems to sealed, regardless. My view is that if your Open Vent system is prone to leakage, leaking somewhere or other issues, you may as well address them sooner rather than later. One, a leaky system will knacker any new boiler in due to the introduction of fresh water into the system, secondly if a pipe goes the F&E tank will just keep filling. Least on a sealed system it'll only loose the water in the system and cause less damage.
Did a combi conversion last year and theirs was OV. On making it sealed it was evident there was a leak. Turned out the pipes had corroded under the wooden suspended floors downstairs, had been leaking for years and made a right mess under there. If we'd just put an OV back in we wouldn't have been any the wiser.
Yes, I accept my line of thinking is flawed.
I have no evidence of any leaks in the drops which are behind the plaster board of the downstairs walls but accept I wouldn't be aware due to the open vent currently in place and that a system boiler would tell me if there was.
Everyone's contributions are getting me thinking (a lot).
Re. Unplugging the sensor- yes indeed you reminded me the rep. said that today. He said an awful lot and it's true to say I can't recall every word.
It would be a bit surprising if this intergas approved.
I'll obviously stand to be corrected, as always, but the Intergas Technical Manager, David Stanley, speaking about the HRE & Eco RF combi tells viewers of a Youtube video how to convert the boilers to an open vent by disconnecting the pressure sensor.
It's at 7 mins 30 secs on this clip
Still doesn’t sound a particularly professional step to me. Look Stan if you want Intergas go with Intergas I think you could get a lot better ideas if you get quotes from other companies. Even if you don’t use them. That’s my opinion. I can’t really see the appeal of Intergas myself but there we are. I think a lot of the positive reviews will be down to the fact that they are still a relatively new player to the uk market so common faults will not be appearing yet. Also as said before, in my own limited experience, the one time I’ve worked on one and needed a part it had to come from Holland. I just think you need to think long and hard about what you’re trying to achieve long term as this just doesn’t seem the cost effective way to do it
Separate the boiler from the system with a plate heat exchanger and fit a Viessmann Vitodens 200 that will modulate nice and low.
Regardless of which boiler I fully agree that the principle of fitting an intermediate heat exchanger really is the way fwds for the future...when we have had some spare time we have been exploring this area.
In fact once my new workshop is up and running ...is into this area we are heading. Even if it is a sacraficial unit deduct cost of a
magnetic type filter and boiler parts damaged by liquid sandpaper it starts to make sense.
Reply to I've settled on an Intergas boiler. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all, this is probably a daft question but I need to run my cold feed from one side of my wall mounted boiler to the other. Running it beneath the boiler is difficult with lots of obstacles, is it okay if I run soldered copper over / across the top of the boiler? It'll be about 4" off the top...
Hi, Later this year I am going away for a 2 week holiday and as the weather will be warm there is no need for the heating to be on and arguably no need for me to needlessly heat hot water. My intention was to turn the boiler off along with the mains water when going away. Now, I have heard...
