Discuss Isolating boiler to test if hex is causing pressure loss in the USA area at PlumbersForums.net
Matt0029
If Isolating a boiler to determine if the leak is on the pipework or the boiler. If pressurising to 1.5bar then isolating the flow and return for an overnight test. Is it still acceptable to use the combi boiler for hot water? Expansion vessel located in the boiler.
Yes fine to use hot water but it may invalidate your test if the expansion isn’t good enough eg over 3 bar etc
Reply to Isolating boiler to test if hex is causing pressure loss in the USA area at PlumbersForums.net
Hi, I have a Worcester 28i junior boiler that has started to lose pressure, only when using the central heating. When using hot water I have no issue, however, when running the heating the pressure drops. Im looking for some ideas on what could be causing this. I have no sign of pipe leaks...
