Discuss Is This My Radiater Drain Valve? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
E
egg661
Hi guys, there does not seem to be a drain valve on any of the downstairs rads. However this is outside and is in line with the radiater pipe in side the house. Could it be the Drain?
[DLMURL="http://www.ukplumbersforums.co.uk/redirector.php?url=http%3A%2F%2Fwww.uploadit.org%2Fmy.php%3Fimage%3Dhttp%3A%2F%2Fserver3.uploadit.org%2Ffiles%2Fhondavfr-16072008080.jpg"]UploadIt.org Image Hosting[/DLMURL]
I have undone the nuts but it appears to be blocked off at the top
[DLMURL="http://www.ukplumbersforums.co.uk/redirector.php?url=http%3A%2F%2Fwww.uploadit.org%2Fmy.php%3Fimage%3Dhttp%3A%2F%2Fserver3.uploadit.org%2Ffiles%2Fhondavfr-16072008081.jpg"]UploadIt.org Image Hosting[/DLMURL]
If it is the drain, if i cut the pipe below the threaded part how can i put a drain on it.The pipe is only 3cm from the floor to the bottom of the thread.
a bit worried it might be a capped gas pipe lol boom!
Mark
URL%5D
my.php
its a bolt.
you can cut it where you like it will be solid.
Reply to Is This My Radiater Drain Valve? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
