Discuss Is this an Oversized boiler? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
hi all,
First post, mostly been lurking about.
I have an issue with my Baxi Solo pfl 50 short cycling. It runs fine for about 45 mins when system starts from cold then starts cycling on its stat about 5 mins on then 5 mins off. I’ve checked flow and return temps from boiler and shows it’s definately cycling on the stat. It does this until the hallway stat is satisfied. I’ve checked radiator balancing and tried pump speeds but doesn’t seem to help. Just added up the radiators outputs at 26000 btus, with this in mind would you expect to see that kind of cycling with a 50000 btu boiler? Cheers
Baxi solos are old has it just started doing this ?
hi all,
Boiler may be over sized for the system, it has probably always done that.
Have you calculated the Heat requirements for the property?
What size of Domestic Hot water Cylinder do you have?
I did have a look on the net about heat requirements but couldn’t find anything that useful, it’s a 15 yr old townhouse with three beds and 9 rads in total. The cylinder is an rm cylinder 120l. The boiler fan (I think) is a bit noisey and I think that’s the reason I have noticed the short cycling. Basically I’m thinking either spend x amount on getting the boiler fan replaced and boiler serviced or replacing completely for something modulating that’s going to save probably quite a bit of money esp if this short cycling is due to it being oversized
As demand is 26000BTUand boiler output is 50000, equal times on and off is about what you'd expect. Is it a problem?
I'm not sure on/off operation in itself is much less efficient than modulating, but a new boiler would be more efficient for a number of reasons. However, it would take a good many years to recover the cost.
Reply to Is this an Oversized boiler? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all I've been reading about the Drayton Wiser system and along the way I began to go down a rabbit hole learning about heating system optimisation and efficiency and i've come to the conclusion that the boiler in my property is way oversized for the requirements, The property is a 4 bed...
3K
Evening All, Been having on and off issues with a Greenstar CDI classic Combi were the hot water is not heating up but only intermittently. Some days/ weeks it’s fine and works fine all of the time but on the odd occasion it’s been running cold in the following sequence. It fires up the boiler...
We are experiencing an issue with CH short cycling on a Worcester Bosch Greenstar 25i ErP boiler. From a cold start the boiler fires for only ~25 seconds before exceeding the set CH flow temperature and entering it's 3 minute short cycle programme. As soon as the short cycle programme kicks in...
Hi All, In Dec 2023 I had my annual boiler service and asked the plumber to change 2 radiator valves as the radiator in the toilet downstairs was not working. He changed both valves and still the radiator was not working. He put some chemicals in and said it should break up anything that is...
Hi I'm having issues with my wireless Honeywell thermostat. It's sat in the living room, set at 18C currently. It makes my Worcester Greenstar 18Ri to short cycle. So, the moment it gets cold outside my boiler works for about a minute, then stops, and starts again in about 5 minutes, then...
2K
