Discuss Is there a future for vented systems? in the Central Heating Forum area at PlumbersForums.net
Coming from Canada, and having lived in Europe for some years, I was a bit surprised that people still install vented heating systems in the UK. As a kid I lived in a 1912 house with original cast iron boiler and radiators, and I remember the expansion tank with sight glass, it was in my room, but new vented systems disappeared decades ago.
Does any country other than the UK still use vented systems? Either for heating or hot water?
Surely sealed systems are much better, especially since radiators are mostly made of mild steel?
Personally I wouldn't install any new systems as a Vented system, they would all be sealed systems that be for HW and CH systems.
On existing heating systems we always try to replace Vented ones and convert them into sealed - the most easy way to do this is replace the heat only boiler with a system boiler. I find 9/10 it's easy enough to do this and saves hassle down the line.
IMO if a system is vented it should be converted to sealed when it comes to replace the boiler.
Why do you think this is the case? It's true that there are still a reasonable number of heating systems that are vented because they were installed decades ago and are still working okay with the original boiler. But these are normally converted to sealed or 'semi-sealed' systems when the boiler is replaced. The heat exchanger in a modern boiler isn't going to last long unless the system is sealed.
Vented hot water systems, on the other hand, are still relatively common because (a) the DHW tanks last a long time and (b) not all properties have a water supply that is adequate from the point of view of pressure and/or flow for an unvented system. Unvented cylinders are also relatively expensive to install.
Why do you think this is the case? It's true that there are still a reasonable number of systems that are vented because they were installed decades ago and are still working okay with the original boiler. But these are normally converted to sealed or 'semi-sealed' systems when the boiler is replaced. The heat exchanger in a modern boiler isn't going to last long unless the system is sealed.
Are not the exchangers in most modern boilers now stainless? mostly to prevent corrosion from the outside rather than the inside, since they are condensing.
Nevertheless, companies such as Worcester, Buderus and Vaillant make open vented boilers variants specifically for the UK market, although they don't sell them at home, or anywhere else that I know of. It just seems a bit weird.
Why is the UK so slow to adopt sealed systems? It was only 1986 that unvented cylinders became legal here. In Canada you would be hard pressed to find anyone that didn't have an unvented cylinder in 1986.
That's not the problem. The problem is that the HXs have narrow channels, which get blocked by the circulating oxides, etc. from the rest of the system.
Boiler companies sell boilers that are (a) legal and (b) profitable.
I don't know the details of the history. My guess is that the UK regulators were worried about safety and/or the water companies (who essentially controlled the regulations) were worried about the capacity of their distribution network. The climate in this country means that having a CW tank in the roof is a viable solution and the distribution network was sized on this basis.
Here is a typical gas fired cylinder from North America. It consists of a gas ring below a mild steel tank, often lined to slow corrosion. Probably the same design since the 50s, maybe earlier. The pressure relief valve just dumps onto the basement floor. Depending on the water supply hardness, they either scale up or rot. Never heard of one exploding. Changing them is a DIY job in most places.
[automerge]1577924383[/automerge]
I beg to differ. The move from mild steel or cast exchangers to stainless was to combat rot from corrosive fireside condensate.
Open vented systems are ideal for larger houses with multiple bathrooms. They provide copious volumes of high level intermediate cold water storage essential where local demands on the utility mains water supply exceed its ability to satisfy. Sealed systems are ideal for smaller properties and modern toy box houses with limited utility space. Originally larger homes had a well and water was pumped up a roof tank made of slate sheets. centralheatking
There is most certainly a future for existing vented systems, mine was installed over 42 years ago and I still have have my original (3) upstairs rads. The key factor in both systems is to avoid/detect any leakage(s). My system is still in pristine condition even though I have only added the odd drop of inhibitor over the years.
I have a bit of a bee in my bonnet re the recommended E.vessel pre charge and filling pressures as some boiler manufacturers were and still might be recommending that the pre charge and filling pressures are the same, if so, then there is no water reserve whatsoever in the E.vessel with a cold boiler which results in more (nuisance) frequent top ups but in lots of cases the top up PRV is left open all the time ("auto fill" mode) so one doesn't know of any leakage(s). Of course the same can be said of vented systems with a mains (ballcock) supplied F&E tank, I have a isolating (service) valve on mine which is "permanently" closed and I open it a few times per year to check for any make up/leaks, strangely enough I have never seen it making up even though one would think that there should be some slight evaporation from the open topped F&E tank.
I have also seen mentioned (on here) that some boiler manufacturers will not honour their warranties if the E.vessel is found to be of insufficient capacity which I find rather strange to say the least as a E.vessel is not a safety device, per se, since it can and does fail (ruptured diaphragm), the boiler PRV IS the safety device and is or should be always set to the working pressure of the boiler which in some cases now is 2.5 bar, it was formerly, in most cases, 3.0 bar.
A bit off topic but a plumbing friend of mine told me that he found it much easier to remove the baffles from a grant oil condensing boiler if he reduced the system pressure to 0 bar.
I was thinking mostly for heating rather than fresh water, but I suppose in the case where mains supply is very poor then there could be some benefit to buffering that with a tank in the loft, although I would have though a pressurized system like what you use for a well would be better.
Is there are reason there are so many places with poor mains supply in the UK?
[automerge]1577965565[/automerge]
You have now:
That site lists stats for fires, not explosions, although there is a lot of talk there about explosions. Perhaps they couldn't find many actual explosions? It is always possible that some yo-yo screws a plug in the PRV, but even then I doubt it would explode.
Notice there is no expansion tank on that system? Ours didn't have one either.
I still install vented systems normally find / tend to install them in the middle of no where as the water pressure isn’t great so you haven’t got the pressure to seal or enough for a combi
and they don’t want to go down the route of break tanks and pumps etc
so yes they do have there place
Reply to Is there a future for vented systems? in the Central Heating Forum area at PlumbersForums.net
