Discuss Is that possible question mark ? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
O
Old Account
Hi lads,
I was going to ask you guys if this would be possible. I wanted to put my glue through the old grill and block it off from inside as there is no other way of getting the flue out. I obviously will seal it properly off.
Below is the picture.
I will block of right at the front of the grill and from inside
I just double checked with Vaillant and they said it’s fine as long as it provides a seal. It’s perhaps not the greatest in the look but will do
No would need to block it up / brick it up from the outside
Can’t just seal the inside and leave the outside with a flue in the grill
It’s fully sealed outside and inside. I wouldn’t leave the flue hanging outside the grill without making sure it’s blocked off. I can see plenty of people done it ...
So your removing the grill and box
Need to remove the box as well
Reply to Is that possible question mark ? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
