Currently reading:
Is a combi boiler safe with NO mains cold water? (Urgent)
Discuss Is a combi boiler safe with NO mains cold water? (Urgent) in the Plumbing Jobs | The Job-board area at PlumbersForums.net
L
Lycanfox
Thanks in advance for any replies to this.
Basically this morning a hot tap would not turn off and was gushing hot water. I couldn't find an isolation valve for the tap so had to turn off all the water via the main stopcock. The only worry is a plumber I rung said that without the cold water going to our combi boiler, the heat exchange could melt itself and cause a lot of damage so we had to turn our heating off.
Now correct me if i'm wrong but surely as long as the hot water setting is turned off on the boiler, the boiler should have two different heat exchangers so the hot water one would not melt due to not having any water to heat if it was off, and the heating exchanger works on a closed loop so should also be ok?
Thanks again for any replies, the last thing I want is to destroy my boiler in such a cold winter.
Adam
Lets get this straight, has anyone checked the MI's? I have. This boiler does not have a seperate plate heat exchanger. Its heat exchangers HTG + DHW are both located above an atmospheric burner. So when it calls for HTG it also heats the DHW side regardless of DHW demand. So if the DHW side become empty through evaporation because the water is turned off then the consequences could cause damage.
Agree with everyone if it had a seperate plate heat exchanger heated from the main HTG heat exchanger through a diverter valve. Which is the normal for all your Vaillants, Worchesters ect, but not for an old ferrolli Modena.
Also agree that the overheat would probably protect it. but would not rely on it as thats your last line of safety device.
i have and here they are for your perusal
http://www.ferroli.co.uk/wp-content/uploads/brochures/archives/Ferroli F30 B Manual.pdf
I have the mi's already and have checked it out, as I said in my previous post.
Anyway its only a problem if the DHW side dries up. so as long as there is water in it no problem.
If this faulty tap is below the boiler do you think it will dry out. So waters off tap is on, even if its above the boiler, what if they turn on the kitchen ho****er tap which is likely to be below the boiler. It will drain the heat exchanger just above the gas burner which is happly burning away because the heatings turned on.
I had thought it is understood that the HW pipe has to be designed in a way that it does not reach temperatures above boiling point under any circumstances?
If you take a close look at the hydraulic circuit it becomes evident that the DHW heat exchanger is (wet) on the primary circuit and therefore, as long as the pump is working (and it will when CH is working) it won't reach any temperature above the flow temperature, consequently nothing will melt or overheating. When there is a demand for DHW the electronics after evaluating the flow sensor signal will stop the pump and the full power of the boiler will heat up the primary cooled down by the secondary with running cold water.
conclusion: from the design of it Dancinplumba is 100% correct.
The frost protection will not work if the electricity and/or gas supply to the unit are cut off.
To avoid damage caused by freezing during long shutdowns in winter, it is advisable to drain allwater from the boiler, the tap water and the system water; or drain off just the tap water andadd a suitable antifreeze to the heating system, as prescribed in chap. 2.3.
Above is from page 6 (1.4), now even Ferroli would not put it in print if there was any chance of it recking their boilers now would they.
I love it when Chris joins in as he seems to find these little one liners from nowhere that supply a definitive answer in hard format.
Right, so now that ones put to bed, what else can we argue about....?
Sorry everone, could'nt let this one drop, so I have done the homework and spoken to ferrolli technical. They say that if you run the boiler with the could water main turned off then there is a significant risk that the heat exchanger could be damaged. Especially if any hot water draw offs were left turned on.
So technical man contradicts the manufactures written instructions, well I know which one I would believe !!
Now please, can we put this one to bed now.
Having read 73 posts and all disagreeing with each other, the "op" must be totally confused.
BTW I get the gist of what an "op" is (the person who asked the question, I assume) but does "op" actually stand for something?
I had already mentioned that ferrolli engineer had warned me of this, but other people know better.
Oh thanks lame for mentioning this again, do you know I missed it the first time you did post it, how silly of me cos had I have seen that a Ferroli engineer had told you that, I would changed my view completely & not bothered to go on & post what I did.
Sorry, I will read your posts very carefully from now on.
So, your tech guy says if cold main turned off then don't run boiler in ch mode ? isnt that like not turning on a hot tap ?
I have spoken to many technical lines in the past I have also worked for a company who had a call centre in there and none of the people were technically trained so were just reading things off a computer screen so if its not written in front of them I wouldnt believe a word they say. As for the ferroli engineer they would say anything to hide the fact the boilers are rubbish and they leak like mad.
You don't know anything about me or what I do. When I say I do my homework and speak to technical, I don't speak to the call centre who apparently know nothing; I speak to the people way above them.
Again for you, if the boiler is unsafe with the mains turned off then is has to be considered unsafe with the mains turned on as this situation is even more dangerous for the customer as the heat build up would then cause superheated water in the coil and even the last plumber should know what happens if the pressure drops aka a tap gets opened.
So can you quote us the page number and paragraph which contradicts my post please?
No because there is still water in the boiler. The temperature the boiler operates at and the boiler controls will not allow this to happen.
Can you elaborate which sensor shall make that happen?
Water is the medium with the most amazing abilities but magic was not one of the ones I have been taught.
Post 68. This refers to long shut downs, ie example of summer holiday home shut down in the winter, therefore not in use.
In summary:
The manufacturers instructions do not say you can use the boiler with the cold water supply turned off.
Ferroli's reasarch and developement team say that operating the boiler under these conditions could result in damage to the heat exchanger.
But the heating frost protection is still in place & so boiler can fire with HWS drained as per the MI instructions?
Anyway the real point is that Ferroli have designed & built a boiler that if the heating is on & the mains water supply is interrupted at any time to it, then there is a real risk that main heat exchanger will be damages, if you & they are to believed.
If true this is a terrible admission that a fairly common occurring event will wreck their product, doesn't go anyway to improve an already poor industry reputation.
Appoligies to all if I have offended anyone. I will retract from this thread as I do not believe there is any thing constructive way forward.
Reply to Is a combi boiler safe with NO mains cold water? (Urgent) in the Plumbing Jobs | The Job-board area at PlumbersForums.net
