Discuss Invented pressure rising! in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
System Oil boiler has been loosing water through the pressure release valve so when system is cold the guage is showing pressure is too low and needs topped up.
(This shows to be the isolation valves for top up loop are fully shut off)
Expansion vessel was replaced with new one and still having same issue 😭
Pressure gauge showing pressure going up to 3 bar so looks like pressure release valve ok.
There is no automatic bypass but there are 2 towel radiators without thermostat valves.
Any ideas as to what could be happening here please? 🥺
I'd recommend getting a professional to take a look.
You have several issues here that tell me it needs assessing by a qualified engineer.
1: pressure shouldn't get near 3bar in normal use
2: pressure loss could be several things
3:the use of 'invented' rather than 'unvented'
How many rads do you have and if double or single panel and can you read off the expansion vessel volume and we can do a few calcs which may help. What is the boiler output.
Reply to Invented pressure rising! in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
