Currently reading:
Installing rads for GSHP
Discuss Installing rads for GSHP in the USA Plumbers Advice area at PlumbersForums.net
Hi there!
Recently moved in to a new property in Sweden, previously heated with fires and electric rads. Have contracted someone to install a Ground Source Heat Pump, but will undertake the installation of rads myself. The property is around 120sqm over two floors, and I will be setting in 11 rads. The pump will be a Nibe F1226. I've purchased a bunch of old cast iron rads, which will fit in well with the style of the house. Advice for a heat pump system is to avoid TRVs in main area of the property. The ground floor is open plan so I will not use any TRVs there, only in separate bedrooms upstairs where one may want to draw down the temperature independantly.
* I will repaint the outside of the old rads. Is there anything more I should do to refurbish them? Flush out the inside of any crud? Rinse through with an inhibitor or something? Pressure test for leaks?
* In the absense of TRVs should I have separate shut off valves for every rad? Or can I get away with isolating a few separate zones? (EG if I have three rads down one wall, can I just stick a pair of shut offs at the beggining of the run?
* What about lockshields for balancing? Do I need one on every rad? Bearing in mind that a GSHP will run all the time at a lower temp, will balancing even be an issue?
Thanks in advance!
Tom
I have only used underfloor heating on ground source heat pumps , I have used radiators on air source these were either triple steel panel oversized to compensate for the low heat temperature delivered, I have also used fan assisted radiators to move air across the internal heating coil this was quite a good method of achieving a even spread of heat to a large room , cast iron wouldn't be my choice but I would advise power washing them out and pressure testing them, if you use them valves would be needed usually connected top and bottom opposite end , follow the manufacturers instructions regarding inhibitors and or heat transfers fluid . Regards Kop
Reply to Installing rads for GSHP in the USA Plumbers Advice area at PlumbersForums.net
