Discuss Installing new gas appliance in rented house. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Matt0029
A I correct in saying that when you install a new gas appliance in a rented house. There is no need to write out a CP12 and test all the other gas appliances in the house. Thanks.
Yes. You dont need a CP12 for new stuff. Technically, when the CP2 is due, if the new appliance is less than 12 months, it does not need tested. But that would be daft, as it would be due before the rest.
As soon as you turn the gas off technically you are responsible and should carry out a minimum of a visual check of all other gas appliances.
what if you dont turn the gas off?
Reply to Installing new gas appliance in rented house. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
  • Article
A Plumber Who Worked Illegally Gets A Suspended Sentence After Falsely Claiming To Be Gas Safe Registered. A Plumber in Herefordshire was prosecuted after Hereford Trading Standards Team found that he was falsely claiming to be on the Gas Safe Register when he was not, putting members of the...
