Discuss Installing a toilet downstream of another in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
Hello, I'm reworking our ensuite which is next door to the main bathroom.
I want to connect the new toilet into the existing soil pipe which runs directly under it.
See the picture below for the layout.
Can I simply put a strap boss on to the existing soil pipe or is there anything I should be aware of?
1. Do I need an AAV and where should it go?
2. I don't have space to put a swept connection in on the new toilet, it'll probably have to be a 90Ā° connection into the horizontal soil pipe. Do I need to put some sort of backflow preventer to prevent stuff from the new loo sitting in the pipe between the two loos?
Thanks in advance, I really appreciate any guidance
Reply to Installing a toilet downstream of another in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
Hello all, Iā€™m replacing a concrete paving slab patio in the back yard. The original patio used 50mm deep concrete slabs on hardcore & sand. Iā€™m planning to pour a 100mm deep concrete patio on 100mm hardcore. In order to achieve the same final height to line up with the rest of the patio, I...
