Discuss Inhibitor application in the Plumbing Jobs | The Job-board area at PlumbersForums.net
A
Aqua Mechanica
How do you stick inhibitor into a sealed system that only uses a combi boiler?
Funnel and a fill loop? lol :)
depends, i like using filling loop with concentrated products designed for injection with a calking gun, fernox make this. Failing that I use an injection bottle (you can get them from any plumb centre/HRPC/etc). Some engineers I know believe that injecting in the filling loop the product can go straight into the expansion vessel but i can't see how.
Thanks for that, so apart from filling loop, where else would you inject it? into a rad??
I know you can get combined lockshield and drainoffs.
Drop system pressure,isolate radiator furthest from boiler, Remove bleed valve and inject chemical itno rad! replace bleed valve, re-pressurise sysem! jod done....
I put mine in through a radiator bleed valve.....i was advised to shut the rad off..then inject and close up then open the return to allow it to flow....
I think mine was fernox or summit and the destructions were on the packaging.....
To make it a bit easier a compression elbow will screw into the top of rad where the bleed valve goes, makes it easy to pour in.
Reply to Inhibitor application in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Good afternoon, I am experiencing a pressure issue with my heating system and was hoping to receive additional insight as to what the problem...
Hello, I live in a two floor semi with a gravity fed conventional gas fired boiler (Potterton Kingfisher MF). The boiler is fed cold water from...
Desperate for some help! Be a life saver of someone can help as suffer from a high intolerance to noise. Moved into new house 1940s (copper...
M
Hi, we have a back combi heater. Whenever the heating comes on it seems to lose pressure within a few hours and I have to refill each morning...
Hey, I've got a Grant Vortex that's leaking water from the seal around the expansion vessel - it's the round type about 50cm wide. The system is...
