Discuss if you install and repair things in the Plumbing Jobs | The Job-board area at PlumbersForums.net
free one off adey we bought there flusher thingyI thought you used that centramag filter??
Gas man pm me your address I'll send you some 22mm end feed elbows! :devilish:
Dont lie you use plastic
was gonna say something similar but then realised he wanted to make it easy to dismantleGas man pm me your address I'll send you some 22mm end feed elbows! :devilish:
see if you can work out why the comp bends there cunny funt:30:Gas man pm me your address I'll send you some 22mm end feed elbows! :devilish:
ignore adam,he,s always like thiswas gonna say something similar but then realised he wanted to make it easy to dismantle
make it easy for yourself if it fails,built in easy maintenance,all our jobs are like this
dont ever touch boiler isos,they always leak,its a combi above itwhy do you need the valve on the inlet ?isnt the pump valve or boiler iso just above?
its all going in a top to bottom unit with removable false back,otherwise they will turn them off trying to put water in LOLYou sold the client a good idea mark ... Not many would go for the additional cost of all the fittings .. I'd probably advise on boxing it all in with a removable panel though!... lots of things on show that a custard can mess with there, you know what they're like...
Reply to if you install and repair things in the Plumbing Jobs | The Job-board area at PlumbersForums.net
