Discuss Ideal Vogue 26 KW combo high co reading in the Gas Engineers Forum area at PlumbersForums.net
HI all,
finished fitting the above boiler yesterday. Straight swap, side access flue with only the elbow off the boiler.
Gas pressure 21mbars on full chaff. (right by the supply)
when doing the co checked, minimum was as expected- 3ppm, .0.0000, and about 7,8%
Max on the other hand was 240ppm, 9,8% and 0.0022. waited till the next day to check, and the ppm did come down to 210!
on speaking to idea, and saying, "yes, I have checked the flue connection and it is fine, and yes the gas pressure is correct", they said that the CO reading will probably come down, and anyway, the readings are within tolerance and they would probably not come out. I confirmed that they were saying they were happy to let me commission it and they said yes.
Now, I have had this before with Vaillant boilers, and ive gone back the next day and its all settled down, but I found their lack of interest, interesting.
has anyone else had this with them?
Reply to Ideal Vogue 26 KW combo high co reading in the Gas Engineers Forum area at PlumbersForums.net
