Discuss Ideal Logic Code Boilers & Green Deal in the Plumbing Jobs | The Job-board area at PlumbersForums.net
G
Greenerdeal
Hi, I'm interested to know any views on the Ideal Logic Code boiler range with flue gas recovery.
Like a lot of people currently, I'm looking at a new boiler & flue gas recovery unit to access funding from the latest Green Deal scheme. A lot of installers are recommending the Ideal Code boilers. I can see it's a neat solution as the flue gas unit is built in but is the recommendation possibly based more on ease of install/price point/installer incentives?
From what I can see, the Logic Code is based on the oldest current Ideal boiler range (ally heat exchanger, well documented reliability problems etc) and was originally aimed at the budget new-build housing market. Is this about right or am I being a bit unfair?
The Baxi/Potterton, Vaillant and a few others boilers available with a separate flue gas unit look better boilers on paper but are a fair bit more expensive & take up a lot more space.
Any thoughts or better still experience with the Logic boiler appreciated before I take the plunge....
Logic is brilliant way above valliant interms of Eco design and installation, I would much rather a logic combi than a valliant. Baxi one is ok but heat recovery unit isn't as tidy as code
Reply to Ideal Logic Code Boilers & Green Deal in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have an ideal vogue max S18 boiler and I’m considering fitting auto balancing TRVs, my question relates to the boilers pump. I see a boiler...
