Discuss Ideal imax w45 banging noise. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Christopher buzzard
Hey. Got called to the above boiler with complaints of a knocking noise. When I arrived I found the pressure to be over 3 bar. The filling loop had failed. Took pressure down to 1.5bar. Fired up boiler again and the knocking noise still persists. Sounds like a rocks in a washing machine. Thought trapped air so replaced aav on top of heat ex but that hasn’t made a difference. Pump is working fine, auto bypass fine, rads and hot water getting up to temp. Partial blocked heat ex?
You commercial mate as I’m sure Ideal class this boiler as a commercial ?
May be wrong tho
Np
Reply to Ideal imax w45 banging noise. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
