Discuss Ideal Icon. No central Heating Fault, Any advice greatly appreciated. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
N
nafe
Hi all,
I have a fault with my central heating system,Boiler is ideal icon he15 (I didn't choose it!).
Working perfectly for hot water only, but when I turn on the central heating, the boiler light instantly goes out.
If I turn the boiler on for just heating, the boiler ignites, then makes lots of banging (kettling) noises then the boiler powers down, some auto cut out?
Approx 6 mnths ago I had the same noise, a good friend of mine then took the small condense trap out of the boiler, and there was a blockage as water poured out, maybe 2 pints, we then put a compressor on the waste pipe, which did the trick.
I have checked the trap this time and only a very small,normal amount of water came out of the trap.
So my thoughts are the system needs a flush?
But maybe Heat exchange?
Thanks for your help guys.
Nathan
Thanks for reply.
I had an engineer look at the system earlier, he advised flushing the system.
But he hasn't a lot of experience with icon icos boilers so I thought it might be worth seeing if anyone else has had similar issue.
Honestly it sounds like the heatex is blocked/knackered and the boiler is going to overheat. Hard to say without looking though. It may be resolved with a chemical flush/scale reducer, but maybe not.
Get it flushed properly and if that doesn't work, get a new boiler installed with sufficient protection from scale and corrosion to prevent this happening again. I wouldn't bother repairing your boiler if it needed a new heatex, it's not economical.
Sent from my iPad using Tapatalk HD
If the hot water is working properly the fault must be external to the boiler. Possibly a blockage in the heating pipework which is why someone has recommended a flush.
I shouldn't be giving out advice at midnight when I'm in a mood lol. I clearly didn't even read his post properly.
Thanks guys,
Flush will be taking place on Monday, hopefully that will sort it.
Bought some sentinel x400, and a qualified engineer will be doing the flush.
If the boiler is on, for only hot water it's fine, if I then press for heating it's fine, but as soon as I turn hot water off the boiler cuts out.(led flashes)
Ill post again on Monday pm
thanks for all the advice
Reply to Ideal Icon. No central Heating Fault, Any advice greatly appreciated. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
