Discuss How to stop hinged shower screen from moving in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
We have a hinged shower screen attached to a bath. It swings backwards and forwards. However, we want to stop this movement so the screen stays in a fixed position.
Can someone help achieve this please.
There should be a seal on the bottom edge of the screen door that holds the door in place and prevents water leaking past. Either it's missing or worn, measure the gap and the glass door thickness and find what fits.
https://www.NoLinkingToThis/c/bathrooms-kitchens/shower-screen-seals/cat11380001
To stop it moving a dab just short of the end would suffice.
However if it leaks then a continuous bead is required.
Why do you want to stop it moving? It will be difficult to reach the taps when it is fixed.
If it’s because it moves during use - this would be solved by replacing the seal as suggested in post #3
No bath panel or it's removal might suggest it's been letting water by so it's an issue. Best replace the seal because as suggested above you'll want access to the taps or that part of the bath from outside at some point.
Reply to How to stop hinged shower screen from moving in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
L
Good morning, I have a hinged shower screen for my bath that I don't have fixings for. The guide holes in the screen line up with guide holes in...
Hi I had to remove the glass panels from this quadrant shower cubicle and I'm struggling to get one of the screens back in place properly. The...
Hello all, I'd like to get some advice on the following issue. We have relatively large tiles (see image 1), and the idea was that the vertical...
A
Hey, here goes and I hope it works.. never used one of these before! I have a Sagittarius Ergo mixer shower min bar of pressure required 1 bar...
Hi all I really need some help or advise….. Back story….. Some years ago my dad had an extension to his house which included a newly built...
