Discuss How to run rad pipes through 80 Celotex? in the USA area at PlumbersForums.net
Hi again.
Builder will soon be laying the floor in our new extension. It's currently a concrete slab and he's going to lay a thin (a few mm) of sand on this to level out any imperfections, lay 80mm insulation (I guess will be 'Celotex' type stuff) and then chipboard flooring on top. I need to get a couple of 10mm CH pipes from one side to the other...
How best to do this? It'll be across the middle of the room, so not around the edges.
I'm planning to use 10mm plastic-coated copper tube - it's only going to feed one rad of around 4700btu, and being copper it won't be springy.
My thoughts are to cut a 'V' slot in the top layer to just past half depth, trim around 20mm of the bottom of the removed V sections, lay the pipes and then glue the V back in place, and tapping it down with battens to get it flush. Is that a plan?
If so, would you leave the pipes loose in the slot, or use foam or similar to fill the 20mm void?
Or, what is the correct way to do this?!
Thanks.
Thanks Scott.
Surely that would mean, tho', that the builder would then have to channel out the underside of the insulation? And the pipes would not be as well insulated either since they'd be close to the concrete slab?
Pipe in pipe is normal practice as Scott has said, you could however lay a strip of 40mm celotex type insulation across the room fixed down and then lay the 10mm copper plastic coated pipes in this layer tape over with aluminium foil tape, then lay another 40 mm on top this sandwiching the pipework in-between two layers of insulation the remaining 80mm will butt up to this and be taped over. Regards Kop
Reply to How to run rad pipes through 80 Celotex? in the USA area at PlumbersForums.net
Hi All My radiators were full of sluge/residue so I put in a flushing point and flushed then through with fresh water by connecting a mains hose...
I need to run central heating pipe horizontally under the floorboards of an upper floor. I need to go through only one 75mm wide beam, but I'm...
2K
This maybe isn't so much about asking for advice as giving it 🤔 I had a leaking HW cylinder (23 years old) that I got fed up patching up with...
2K
Hi All, Looking for some advice, I was looking to extend my drainage for a new conservatory however after breaking through a concrete floor and...
2K
Hello everyone! I'm finally getting to do my own bathroom renovation (spend most of my time doing everyone else's). The bathroom is on the ground...
4K
