Discuss How to remove Shower riser rail in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
jsm
Hi
Trying to remove the riser rail, but cannot see any way to take it off, can't see any grub screws etc... Any help appreciated
Yes, it looks like a Mira one. Using a flat bladed screwdriver, or similar, prise in between the tiny gap and push it down (indicated on edited photo), this should hen reveal a screw.
The grey coloured end bit will be concealing the screws.
It will slide off, either downwards or forwards away from the wall.
Although a sharp tap with a hammer would suffice if necessary.
Reply to How to remove Shower riser rail in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
