Discuss How to fix dripping tap in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi, my tap is dripping. It’s not constant. Sometimes if I try that extra tighten it stops but most of time slowly dripping
It’s dripping from the tap where water comes out. Not below or near where turn off.
Can anyone advice how I fix this? Or do I have to replace the whole tap
Thanks in advance
From your description with giving an extra tighten, I’d say they’re traditional screw down type taps, so would probably just need a new washer, sometimes it’s the seating, but doubt it.
Reply to How to fix dripping tap in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
