Discuss How does a boiler sense the condensate pipe is blocked? in the Central Heating Forum area at PlumbersForums.net
Thanks oz-plumber, I did wonder if perhaps sensor failure could cause the same effect (boiler shutdown/lockout)There are sensors in the heat exchanger that are specific to this fault.
They detect the condensate level in the heat exchanger and hence attribute the fault to condensate blockage.
Mind you - 30% of the faults are caused by faulty sensors!!!
Worcester Bosch Greenstar 18Ri.What boiler are we talking about?
[automerge]1587389998[/automerge]
they work on fan pressure
What does? Are you saying an increase in fan pressure correlates to a blocked discharge? That would make sense
Reply to How does a boiler sense the condensate pipe is blocked? in the Central Heating Forum area at PlumbersForums.net
