- Messages
- 5,439
Custard has one that appears to be leaking from the chrome threaded part, at the top. Possibly a hole in it/corroded through as it seeps out when you wipe it off.
But is the chrome bit permanently joined onto the brass bit? Or do they sepaprate? And so if you want to remove it to investigate do you need to unscrew the whole thing off the pipe which I presume from the pic is just sealed with an olive?
And I'm guessing it's unlikely to be leaking from damaged pipe/olive underneath as that wouldn't seep out from chrome threaded part?
Thanks for any clues/suggestions.
https://www.victorianplumbing.co.uk...j1k2UpL95VKOP6cIymZk-yikQTle4Iffl4aApHP8P8HAQ
