Discuss How do I repressurize my boiler (Intergas kompakt hre) ? in the USA area at PlumbersForums.net
edit: found the way to connect the hose to the regular tap.
Dear everyone,
I am trying to figure out how to add pressure to the boiler. I've read the manuals online and this is what I found:
  • Connect filler hose to cold water tap and fill hose with water until no air bubbles present.
  • Connect filler hose to filler/drainage tap below appliance.
  • First open cold top and then filler/drainage tap.
  • Fill appliance/system until water pressure is between 1 and 2 bar (when cold).
  • First close filler/drainage tap and then cold water tap.
  • Bleed system after filling.
I basically have little idea about what it says, I can't identify where I should connect the filler hose to. Please see a picture of my setup attached. As far as I can tell, I need to connect the blue hose to a tap, but unsure where to. Could you please help me out?
Reply to How do I repressurize my boiler (Intergas kompakt hre) ? in the USA area at PlumbersForums.net
