Discuss How any wraps on PTFE tape on a threaded drain off valve? in the USA area at PlumbersForums.net
Hello, I was wondering how many wraps of PTFE tape you need to use on a threaded drain off valve that is going to be fitted into a Telford horizontal stainless hot water cylinder. Thanks
Is it a new installation?
You need the G3 qualification to work on unvented cylinders
It is a new installation. The threaded drain off valve hasn’t been installed. I have the G3 qualification. But have only done the course recently and haven’t worked on my first cylinder yet. So I am just checking before I fit the drain off valve. I would normally use 3 to 4 wraps of PTFE tape. Thanks
I do 10-12 wraps and see if I can screw the fitting in by hand alone. If I can't I put the tools on it and do it all the way up. If I can do it up almost all the way by hand, I carefully unscrew it so as not to shred the tape up on the fitting and add another 5 or 6 wraps.
I used to always clean all the PTFE off and start from scratch, just adding more wraps of tape and give it another go if it didn't feel right or leaked. Then an old plumber told me to try what I describe above and I have had much more reliable joints ever since.
As Simon G says, it is a bit of a mystic art too and something you just get a feel for. Also plumbers like to disagree on the best way to do such things so anyone please feel free to disagree with my method! It works for me very reliably that's all I can say.
Now on to paste or no paste.......o_O
Depends on the quality of the materials as well. Some towel rails and radiators are complete tat and need more.
I have had to use a 1/2" BSP tap to sort out the threads on some cheapo towel rails before. When the tappings are that bad it does become difficult to know how much tape will seal them. The again my method has worked fine on those ones too, especially after running the tap through them to clear the threads.
Some radiator tails are taper thread though. On the parallel ones, do you recommend using a string type sealer? I suppose good old hemp and paste would work on a parallel thread well too?
Everything I’ve seen in in UK domestic plumbing and heating has been BSP parallel, some of the wiser guys in here may know better. I guess you have more NPT stuff on the US?
You can often get away with PTFE because the pressure is low. Your generally recommended to use an anaerobic thread sealant like Loctite 577. You can get an activator to speed up the cure time.
Reply to How any wraps on PTFE tape on a threaded drain off valve? in the USA area at PlumbersForums.net
Hello Plumbers I’ve replaced a 540mm high cast iron rad with 740mm high, like for like but still a 20mm valve extension was required. All was...
Firstly im fitting some basin taps, ive now got the washers. Should i use ptfe tape on the basin tap tails/extension threads? If i should how much...
5K
Most of my lockshield valves are the compression type onto the radiator tail. Have just installed a couple of the union type face to the tail...
2K
J
I have an Arteform shower valve in my bathroom - top lever for the main shower head, middle for the handheld hose and bottom is the thermostatic...
Hi All This is following on from thread I made a few days ago but can't seem to find I'm in a bit of a bind with my CH design where I want to...
