Discuss Hot water plumbed backwards now no heating in the Plumbing Jobs | The Job-board area at PlumbersForums.net
U
Underpressure
Hi all,
right, so, please help a man out here :)
my plumber for some unknown reason whilst plumbing the kitchen in that we have just fit confused the hot feed from the boiler and put a cold feed onto it......
the heating was working fine and as normal,
until...
my heating guy came out, attempted to isolate the boiler to change a suspected flow turbine as this is what tech support said to change, and water :nono: everywhere as the pipe was still live due to being plumbed backwards..
he got it swapped, however, we now have lovely hot water, but, the :nono: heating wont come on!
if you demand heating through thermostat it talks to the boiler, pump comes on etc, but does not fire up just pump keeps running?
he's saying to now change the diverter valve as that could have failed and the symptoms match that
no warning lights or flashing ones on boiler
worcester bosch greenstar 24i approx 5 years old
customer is being very patient, but its causing me mega stress
please advise
cheers guys
It is not this diverter valve,which would be easy to check anyway.best he re checks his diagnosis..maybe your heating lad is related to your plumber,or you just have split personalities ...
Any idea what it could be?
You need to be gas safe to work on the boiler,am sure a qualified engineer will sort out OK,
Reply to Hot water plumbed backwards now no heating in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Have a sytem boiler with unvented cylinder with 2 heating zones plus hot water in a house we moved into recently. To start with we were always...
My disabled daughter’s hot water has stopped working. It’s a relatively modern Potterton boiler with an indirect sealed hot water system and a...
Heating and hot water is not working. Plenty of heating oil. I have replaced batteries in thermostat and it seems to be working ok, showing flame...
  • Solved
Hi, I am looking for a bit of advice. Our Gledhill hot water tank was installed incorrectly 18 months ago and has been sending bubbling hot...
J
Hi Can somebody tell me if a standard heat source pump installation uses a pressurized hot water tank? Or will the pressure for the hot water be...
