Discuss Hot water only when heating turned on in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
J
Jamsheed
Hi, we have an HIU unit, which we only get hot water from the taps when we turn on the heating unit. A number of engineer have come in to check but they have stated they couldn't see any issues. Any thoughts? could it be the heating plate?
Reply to Hot water only when heating turned on in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
M
Hello, We’ve recently moved into a fairly old, fairly big detached house (i.e. fairly draughty, but not too bad by any means) with a fairly new...
MartinPod81
M
So a strange conundrum regarding water temp if anyone can help resolve, would be much appreciated. Ive tried to give as much info as possible to...
Afternoon. I have an issue with no water flow from any of the hot taps in the house, I can't seem to find a solution to the issue. System is a...
Hi all, just moved a radiator from one wall to another, straight forward job, heating is working, problem is that on turning on a hot water tap...
