F
fplumber
Got a problem with my Potterton 24 combi boiler. The hot water is lukewarm but central heating is working OK. We had this same problem in November 2008 and the insurance (emergency cover) fixed it by changing the Diaphragm (part no. 5111137) in the Diverter valve at the time. It worked OK for about 6 weeks and soon began to get bad again.
I have looked at the microswitch in the front of the diverter valve for the DHW and the piston is moving and engages OK when hot water starts to run.
What I have observed are these
(1). When the Selector is on Tap water only, the central heating is getting hot as well. (Indication of diverter valve fault? - but what fault and what needs to be replaced?)
(2). When the selector is on Tap water only and hot water tap is left running, the piston on the CHW microswitch side also engages. Should this be the case? (If is should not, what is the fix?)
I have already read many entries on the forum which have been helpful towards my diagnosis but now hoping to get a response from someone with the knowledge and experience that can point out resolution to me.
Looking forward to urgent responses.
Many Thanks
Many Thanks
