Discuss Hot water... hot or hotter in the DIY Plumbing Forum area at PlumbersForums.net
Anyone know how to turn the hot water thermostat down on on a Grant Vortex e26 combi boiler? I've done the obvious and opened the front panel and turned the hot water dial down, but still I've either hot water or hotter water.
The hot water temperature is not controlled by the boiler thermostat
Water temperature is preset on mixing valve thats between the plate to plate and hot water pump.
It can be altered take of white plastic cap then turn stem of valve probably need grips or pliers.
If water is still hot could be thermistor at that point probably better to get competent oil engineer.
Thank you. I’m no expert, I’ll call the boiler engineer. 👍🏻
Reply to Hot water... hot or hotter in the DIY Plumbing Forum area at PlumbersForums.net
Hi they used to say as a last resort you could discharge the D2 pipework at high level and turn it back to the wall. Similar to a combi boiler. I...
Recently had a Viessmann Vitodens combi boiler installed, quite often when the adjacent cold mixer tap is opened the boiler starts for a few...
