Discuss Hot water but no heat worchester 20/25 combi please help!!! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
J
janet52
I have a worchester combi 20/25 boiler. Today the heating stopped working but we have hot water. Can somebody please help us.
Thanks so much
If the pressure is ok I would be checking the diverted valve,the motor has probably gone,there it depends which valve you have as to how you fix it,if it is the later boiler the valve has a cartridge which is always sticking. To be honest you really mead someone who is handy or better still an engineer to fix.there is a lever on one end you can use to manually override.
Reply to Hot water but no heat worchester 20/25 combi please help!!! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
