Discuss Horstmann electronic 7 programmer. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
- Status
Anyone know if the new units are a direct replacement for this older one
Its for a lettings agency I work for. If its a direct swap theres no wiring as its all spade connectors.
If it needs wiring alterations then I am required to pass it to the spark.
- Status
Reply to Horstmann electronic 7 programmer. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, I note that the Grundfos Alpha 2 requires a special plug to connect the electric wiring. Are those plugs reusable if rewiring is needed...
Hi - I'm not an expert but wondered if anyone might be able to assist. I've replaced an old toilet with a new one. I've used the same water inlet...
Hi Folks,
I have a challenge with a Main Eco Elite 30 Combi which is short cycling on the CH. Water works fine. As soon as you have call for...
We moved into our house last year and our current central heating set up is:
Boiler: Vokera Mynute HE system boiler
Thermostats: 2x Robus...
Hi, would appreciate any thoughts on the below. I have an almost 10yr old Ferroli Modena 32S HE system boiler. (I am aware of their reputation...
