Discuss High co readings on a baxi 105e combi in the Plumbing Jobs | The Job-board area at PlumbersForums.net
M
murpho
Had my boiler serviced but the plumber says the readings are dangerous and recommends I fit a new boiler
here re the reading
02.....15.5
co..pmm...27
co2.....3.1
these were taken with heating on
these next readings were taken with hot water tap turned on
02.....9.8
co..ppm ...768
co2.....6.3
are these good or bad the boiler is about 11 years old and has had quite a few parts replaced over the years
thanks for any advice
your boiler does not need replacing just for this issue get your gas engineer to find out the cause
Just call baxi heateam in,they will sort it,may cost ya 200-300 but its worth it,ESP age of boiler
I did a service on a Vokera Linea combi last week with similar readings on similar age boiler........heat exchanger all furred up and burner had a lovely orange tint in the flame!
Stripped and cleaned, put back together and got a healthy blue flame and about 50 ppm
Get an engineer that uses tools as well as an FGA and a pen, before considering a new boiler.
By the way my customers boiler was serviced every year by a well known organisation.......IMHO that heat exchanger had never been cleaned, and if it had then that was a lot of fur for 12 months!!
Like to thank you all for your replies but after looking back over all the bills I have for this boiler I have decided to replace it thanks again
If you post your location I'm sure some local members would be happy to give you a quote
Reply to High co readings on a baxi 105e combi in the Plumbing Jobs | The Job-board area at PlumbersForums.net
