Discuss Hi, question about chasing pipes into wall in the USA area at PlumbersForums.net
Hi, I’m not a plumber by trade but needed PVC pipes chased into wall which I’ve done but the plaster has said they need to be chased deeper because the heat might effect the plaster.
But it’s a internal wall so theres only so deep I can go, so is there anything I can put over the pipes so I don’t need to chase so deep and can plaster over????
Thanks in advance.
Boxing ? Or get the plaster to dot and dab new plasterboard on the wall
Reply to Hi, question about chasing pipes into wall in the USA area at PlumbersForums.net
I’m fitting a small basin on a floating countertop (30x40cm) and will be chasing the internal clinker block wall to around 100mm wide to accept a...
I apologise in advance that this might not make sense or be full of silly/obvious questions, but I am a novice at all this! We have recently...
2K
Hi all, hoping there are answers out there to my small dilemma. A customer of mine wants 15mm radiator flow and return pipes chased into the block...
2K
HI Plumbers, I need some advice on our chased-in pipes. We had plumbers tell us an array of different things. Questions: 1) Do copper pipes...
2K
