Discuss Hi Industrail Sparky here in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi All, ive come from the electricians forums work on the industrial electrical side, Hydraulics and mechanical.
I have an issue with my central heating system, its an old system 8 year old house boiler is an IDEAL ICOS HE12 I have heat on the radiators upstairs but nothing downstairs when I try to bleed them no air in the system, The small radiators downstairs do work but not to there full potentional, the double skin double convector in the living room has heat on the incoming valve it also has a TRV which i've checked isn't sticking, also the kitchen radiator has no heat either, I have fitted a brand new Grundfos central heating pump this has made no difference, been told it could the motorised 2 port's but ive checked for continuity there are ok, I have lived in the house 3 month's first time I tried the heating last week before that the house was empty from last october, also been told it could be a blockage, but the strange thing is the boiler is firing, then cutting out after 15-20mins, i work on industrial boiler im wondering if it maybe the flame electrode? im not sure need a good heating engineer to come and diagnose
im at wombwell, barnsley, s73 8be
cheers Joel
Hi Joel,
your use pump seems to have failed. Upstairs hot and downstairs cold, along with boiler cutting out are all classic symptoms of a failed circulating pump.
That said, it could be the supply to the pump, but as a spark you'll need no advice on how to check that will you!
All the best
Dave
Hi Joel, the system may need balancing. open the lockshield valve and TRV on each downstairs rad fully, and close every lockshield valve fully on all upstairs rads opening them back up by a quarter of a turn, stick the heating on for half an hour and report back.
Oops just saw the OP was from October, guessing he has fixed his problem by now
Reply to Hi Industrail Sparky here in the Plumbing Jobs | The Job-board area at PlumbersForums.net
PSxxxxxx
