Discuss Hi. Could you help me identify this part? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi.
I was looking for this part in B&Q, ScrewFix and Homebase, but with no success.
They told me they never seen this part before. I need something but little longer to fix my pipes under bathtub.
Would be great if you could help me name it.
Many thanks.
Would this work?https://www.NoLinkingToThis/p/mcalp...MKV2LQ3GU1eD6cOmktakFgCCa66RzmwYaAp3AEALw_wcB
if you need to extend it by how much?
If your drawing is of a trap under the bath.
Plain pipe into the threaded part, on the pipe you place; threaded nut, slip washer (red/pink), rubber cone washer (thin end of wedge into trap). Cut this pipe to length to marry up with your existing pipe and join the two together with a straight coupling ( mcalpine T28m)
Should be relatively simple for a plumber. You’d probably pay for an hours labour and materials. Can’t quote £££ as we it varies so much up and down the country
Reply to Hi. Could you help me identify this part? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi sorry im a newbie, pls help if u can. I had a new bathroom installed about a yr ago and since then when i flush the toilet the room stinks of...
Hey folks, I'm wondering if someone could possibly help, I'm looking for a possible part number b4 I call ideal in the morning, I fitted an...
Deleted member 120897
I recently moved into a new flat and both toilets were dripping when not in use. I found that the issue was the flush valve seal and replaced it...
J
I have an Arteform shower valve in my bathroom - top lever for the main shower head, middle for the handheld hose and bottom is the thermostatic...
About 10 months I started having issues with a gas like smell in my home and the gas board was unable to find any gas leak I've still got the...
