Discuss Help with RetroFit UFH in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, first time poster here so be gentle!
Background, im not a plumber but very competent DIYer a ships engineer which basically means i do plumbing and boilers on a rather large scale! so i have decent know how.
But i also know my limits as well.
So basically we have bought a 4 bed bungalow which currently has electric storage heaters (we haven't moved in yet but they are Rubbish)
Ideal thing is to retrofit the house with UFH.
Now we are just starting with the renovation, new kitchen, flooring etc
I have access to the full underneath of the house from a basement, although its not full height i can get everywhere, and there are lights etc there, the under floor is not insulated yet
the debate im having with myself is do i go Overlay UFH or fit from below with aluminum plate like the Clippa Plate from Nu-Heat, this means no height buildup and i can do it at my leisure (for want of a better way to put it)
has anyone installed UFH from below and how has it worked out??
also due to funds i may do the main living spaces with it now and fit rads in bedrooms until i do everything later does this seem silly or like an ok idea?
most likely going for an oil fired boiler (no mains gas etc) or possibly air source heat pump but my knowledge of these are limited and would have a plumber install either and commission the whole system
house is not bad for insulation and id be insulating under the floor anyway regardless of UFH or not
anyway thanks in advance for any advice
Cheers
Overlay system
Remove all the flooring
Install ply in between the joists so you don't increase your overalll height that much
And insulation on the underside of the ply to save wasted heat
Then fit your ufh overboards and sort your flooring out etc
It's best to do the whole job in one and not piece by piece
Hi thanks for reply,
I don't think it would be possible to remove 200m2 of chipboard when I have full access underneath it?
What's wrong with installing from below??
Alu plate, ufh pipe, 100mm glass wool and 50mm kingspan then support wood.
Was hoping to space the pipes at 150mm
Cheers
It's not the best heat dissipation and your heat times will suffer
Ok yeah that is a concern of mine. So the overlay build up of 15mm system would give a much better heat output to room or just quicker warm up?
Then I'd have to skin the bedrooms I was just putting rads in to level up the floors
Cheers
Yes as there's not much on top
You can airing will take slightly longer but nothing negative about doing that
Ok thanks for that, think maybe overlay will work better, engineered wood flooring over the top and i will still insulate below the chipboard floor.
Any other tips? or the best systems if you have any recomendations
cheers
Reply to Help with RetroFit UFH in the Plumbing Jobs | The Job-board area at PlumbersForums.net
We have a three zone heating system plus water cylinder (OSO Super S 250L) on an Valliant EcoTec 637. Two CH zones and a UFH zone. Boiler is...
Hi, I have a 3 storey house built in 1904. We put UFH in the house about 20 years ago. Works well with newish gas boiler. Just curious... I know...
Hi. We have recently bought the ground floor of a Victorian house, about 100 m2. The floors are all laid to very solid floor boards and the...
Hi, I have an 1904 redbrick 2,500 square feet house. We have UFH on every floor. 3 Floors House is reasonably well insulated but far from...
G
HI folks, is it possible/feasible/reasonable to insatll an ufh manifold and system (for a 17m2 room) from a disused CH 15mm flow and return? I...
