C
chris_t
No I'm not a plumber, left messages for my normal plumber and called a 24 agency service but neither have called back. I have an ill 4yr old and no heat so I'd appreciate some help
Vaillant Ecotec 630 plus boiler (couldn't get through to their number after ages waiting) still under warranty. Has the LPG Conversion
Woke up this morning and no heat. The system cycles through a short burn, to pump over-run (S.7) and back to no heating required (S.0)
Thermostat is up (even turning to max makes no difference)
Turning up the required water temperature on the boiler forces a burn, but it reaches temperature within seconds.
So I assume that the water is heating locally but nit going anywhere which is why it reaches temperature so quickly.
Does this mean a pump fail (no fault message)
Could it be the condensate line frozen (the boiler is in its own little room accessed from outside so this is a risk and the pipe then goes outside) but I played hot water over the outside pipe but this seems to have made no difference.
ANy help gratefully received (or any Corgi + LPG plumbers in Frome Somerset area willing to come out today)
