Discuss Help needed to find an 'adjustable' - traditional - wall mounted bath/mixer tap... in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I've been a plumber for a while now but never came across some traditional wall mounted bath / mixer tap with 3/4 inch thread coming out of the wall and being 160mm centre to centre between pipes!
Now I can get a wall mounted tap 150mm apart but cannot find an adjustable one anywhere....:sad:
Anyone got any suggestions please..
See tag for style I'm after but 160mm not 150mm
http://www.pandaonline.co.uk/img/019.2.gif
Thanks in advance
Greg..
Re: Help needed to find an 'adjustable' - traditional - wall mounted bath/mixer tap..
Sorry mate but I cant help, I just think you will bewasting your time to look for it
Never heard, seen, or even needed one like that before?
Do they need the shower ? if not could use globe taps
Can you no move pipe work?
Was going to reccomend this or 3 hole taps but would need access to other side
[DLMURL="http://www.ergonomicdesigns.co.uk/5A0131C00-Roca_Showers_Esmai_Wall_mounted_Bath_and_Shower_Mixer_Kit_5A0131C00.html?ref=base"]Roca Showers Esmai Wall-mounted Bath and Shower Mixer Kit 5A0131C00[/DLMURL]
Seems as if I need a male 3/4 inch to female 3/4 inch off-set connector????
I don't think they exist though..
I've got two male 3/4 inch bsp threaded pipe coming out of the wall. These kits are designed to use female 1/2 inch backplates with off-set 1/2 inch to 3/4..
Am I right? I'm not 100% sure....
Sorry two 3/4 inch bsp threaded pipe coming out of the wall, customer wants a traditional bath/mixer tap.....
Anyone no of anyway to give my customer what she wants?
Thanks for the globe taps advise, I take it they will just screw straight on?
With these wall mounted thing, never can tell until you bought them to be honest, I have had showers that have been completely different, even though they looked exactly the same, I find brita showers have the male connections and cheap showers have the female connection but this doesnt help your situation
Reply to Help needed to find an 'adjustable' - traditional - wall mounted bath/mixer tap... in the Plumbing Jobs | The Job-board area at PlumbersForums.net
