Discuss Help Needed Removing Tap Knobs in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all,
Can someone advise me how I go about removing the handles/knobs on this tap to give them some tlc please?
They look like the type that has a top disc cover on the heads.
If there is a cover, then a blade of a knife might prise them off and there will be screw heads below to hold heads on.
Similar heads have an outer disc at top that needs unscrewed using a strap wrench, but I think yours just has a centre disc, although difficult to see on my phone
Reply to Help Needed Removing Tap Knobs in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi bit of a weird issue, I installed a grohe bathroom tap successfully 2 months ago bought from screwfix. Last week the right hand hot tap makes a squeak noise as I turn it on or off, left tap is 100% perfect and noiseless. This grohe tap is like one unit, so no screw notch or way I can remove...
