Discuss Help identifying parts in the Plumbing Jobs | The Job-board area at PlumbersForums.net
My daughter has moved into a house and we are trying to get to grips with the heating system. Can anyone please tell us what the thing in the attached phots is and what it does.
Many thanks.
Air separator
Top left (15mm) is your fill to the heating system)
Top right (22mm) is your safety vent
Bottom left (22mm) heating flow/ hot water flow
Bottom right (22mm) boiler flow
Looks like an air separator also called by its trade name airject they are prone to scale up ....some experienced heating engineer will be along shortly to correct me and tell you more about it....regards Turnpin
Looks like an air separator also called by its trade name airject they are prone to scale up ..some experienced heating engineer will be along shortly to correct me and tell you more about it....regards Turnpin
It's a turd, that causes lots of problems. Definitely cut more out than installed.
I fitted LOADS of Aerjecs. They did not generally scale up, but sludge or fungal goo collected at the cold feed.
I never recall any call backs to any of mine. But EVERY system (actually few systems complete, but many changeovers) I fitted was cleaned thoroughly, including the header tank.
Actually, and pedantically, that is not an Aerjec, it is of the Tower design, but there are many clones.
Aerjec:
Reply to Help identifying parts in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi All As you can see from the attached pix, the flow control knob on my Bristan shower has broken. It was installed before I bought the house...
Can anyone help me identify which tap/connection it is to top up the system as the level has dropped quite a way below the red marker for the cold...
my bathroom sink (installed 2017) was broken recently and needs replacing. on inspection there is no brand name and only a few markings so I'm...
