Discuss Heating system ? Vented? Unvented? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I had my heating upgraded a few years back by my housing association. I had electric heaters before now I have hot water radiators. I still have a tank in the loft and a hot water tank in the cupboard. Cold water comes from the tank in the loft. Hot water also has low pressure too. Looking at the attached photo, I'm not sure if I have an unvented system.
Please advise, as I'm not sure if this effects the shower pump install that is looming?
Paul
Here we go lol , your CW cistern in the loft may not have enough capacity to supply a pump , any idea of the size , any stickers on the side ?
Reply to Heating system ? Vented? Unvented? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
