Discuss Heating Levers in the Central Heating Forum area at PlumbersForums.net
Hi all - can someone explain what the two black levers are in this picture? Are they for putting more pressure in the heating system? I have a Megaflow Eco Systemfit Unvented Cylinder.
The second one is on the right hand side (not the best picture). So when replacing a radiator I would need to use this to top up the pressure? What pressure should it be?
Yes open one fully then open the second slowly until you hear the water / pressure moving
On the pressure guage 1.2 ish is fine for a cold system eg rads cold
Reply to Heating Levers in the Central Heating Forum area at PlumbersForums.net
Can central heating / gas engineer expert help me with below issue. During winter time only, I have been having issue with low pressure or...
losing pressure
L
 Our heating stopped working today. We've got a Veissmann boiler that's under a year old, and an older Megaflow cylinder, and two diverter...
Have a sytem boiler with unvented cylinder with 2 heating zones plus hot water in a house we moved into recently. To start with we were always...
Hi All, I hope you are doing well. I have old un-pressurised heating system and I need to top up the water but I cannot locate the bloody...
