C
Ceno
Hi, I'm a carpenter renovating my house. I have done all the plumbing (except gas work) under the supervision of my mate who's a plumber. During fitting a new bathroom, I had been struggling to get a seal with a pan connector onto the toilet, which turned out to be a big lump of stray ceramic stuck underneath the outlet. Because I had spent so much time with my head round the toilet, I noticed a sewer smell. The same smell was there two days after successfully sealing the toilet. It was in the cistern, and in the toilet after any time with the seat down. I could not understand how sewer gas was getting through the water trap in the bottom of the toilet. After a bit of thinking I decided that as the cistern was fitted to the pan correctly, the only way for the gas to get in was through the internal overflow. I poured a gallon of water through the overflow pipe (inside the cistern) and not one drop came back into the pan. If water can bypass the U then so can sewer gas! I have spent a couple of hours searching the net for this problem, but found nothing. As I was sure this toilet didn't comply with regs, I phoned WRAS, but they said it's down to the installer to ensure that sanitry ware complies. The supplier has agreed to send a replacement, but I wouldn't be surprised if it's a design fault. Has anyone ever come across this problem before?
