Discuss Hand made copper tap - swivel action? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi everyone!
I've just made a kitchen tap for a customer. She's delighted with it as it is but its wrecking my head that it doesn't swivel. I can't imagine a fitting that I could have soldered in that would give a water tight swivel action and equally as important, keeps that all copper look.
Then I saw a pic of a hand made copper tap on instagram and it looks like it has one? Could I be right??
This is the copper tap I made:
Connectez-vous ou inscrivez-vous pour voir le contenu
And this is the one on instagram:
Oliver Archibald on Instagram: “Built my self a tap. #plumbing #copper #Featherfinish #plumbproud #art #propercopper @archieplumbing #StupidFackingTap #properCopper…”
And before anyone comments on mine I did want to make it out of end feed fittings but here in Ireland everything is imperial so I only had 3/4" pipe and 3/4" solder ring fittings. The plumbing shop had to 'order in' the end feed and they were 22mm. The guy said "just fill it will solder"! So I didn't.
Cheers!
Adam
Well spotted!
Yes & No. IT will work well IF you blather it with a high tack silicone grease. It will be tight at first but should ease up.
However, it will need replacing every so often so make sure whatever you use is properly demountable so it can be replaced.
BTW could not see yours!
Another way of doing it would be to use a compression coupling and instead of an olive use an O-ring or two. Drill & tap one face of the nut to take a grub screw. Tighten the nut so that the O-rings are compressed 'just enough' and then use the grubscrew to lock off the nut.
This was my one
Looks very smart, well done! As you're not having to solder in situ some end feed couplings next time would be killer?
Yeah that was my intention but In Ireland nearly everything plumbing is imperial. I got end feed fittings (which were 22mm) but they were quite loose on the 3/4” (21mm) copper pipe so I had to use the 3/4” solder fittings. Shame really
Reply to Hand made copper tap - swivel action? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
