Discuss Gurgling from badly designed discharge pipe. Any way to lessen problems? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Any ideas as to what can be done to reduce the impact of induced syphonage in this situation?
One badly designed (too long) 40mm wastepipe is used for the bath, basin and kitchen-sink. Inevitably there is a good deal of gurgling when, say, the kitchen sink is drained as it ‘pulls’ noticeably on the bath-trap. I have tried fitting
this type of trap to the bath but it makes negligible difference. Would fitting a P-trap with an anti-syphon attachment be worthwhile? I also have a 40mm AAV – maybe I should install that instead?
Thanks in advance for any advice.
Put an anti-vac trap on the kitchen sink. You want to break the vacuum before it forms ideally...
Thanks for the advice. Actually adding an AAV here is not going to be straightforward as the twin sink has its own pipework as its OD is not compatible with 40mm. It looks like I am going to have to rerun quite a lot of this if I am to get the AAV on the section between the sinks.
Reply to Gurgling from badly designed discharge pipe. Any way to lessen problems? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi. DIY guy here, not a plumber of any experience. I would be grateful for constructive critique of the drainage design presented by this diagram...
2K
Hi, For quite some time now I've been getting quite bad sewage type smells after using my washing machine. I also get water coming up through the...
3K
Hi guys. I moved into a house where the kitchen was moved from an upper floor to the ground floor, at the back of the house, so there was no...
2K
Aquarius
A
Hi, Need some advice about a soil pipe in 1966ish built ex-mod property. We have suspected but not be able to prove that since some heavy...
16K
Hi. I own a three storey house. 4 toilets. 3 showers. Since I moved in a couple of years ago there’s been a recurring (and very mild) sewer...
3K
